Lala2323
Mar 19, 2020Aspirant
Daisy Chaining
Looking for knowledge before I attempt the install. Looking to boost our wifi purchased two routers: NETGEAR Nighthawk X6S AC3600 Tri-Band Wi-Fi Router NETGEAR - Nighthawk X4S Dual-Band AC2600 Rou...
Lala2323
Mar 21, 2020Aspirant
ahh ok... if I stick with the routers do you think it will be ampel coverage for the size of house?
or truly what would you recommend?
Mar 21, 2020Guru - Experienced User
see what I wrote above. I'd recommend a router + triband mesh extender or a full mesh system like orbi.
running a router plus trying to setup an additional router can be done but its more expensive and isn't as seamless.
if you haven't bought the router/routers yet, then I'd investigate the other routes.
- Lala2323Mar 21, 2020Aspirant
thank you again for all your help..
I did buy the nighthawk AC3600.... but I can take it back. Since we are on the train of advice, which one would you get?
- plemansMar 21, 2020Guru - Experienced User
Lala2323 wrote:thank you again for all your help..
If you're wanting seamless coverage? I'd watch amazon for orbi renewed deals. I've picked up a couple RBK53 systems for relatives for super cheap and they've worked great. I'm not sure if the investment to Orbi AX is worth it right now.
but thats just me. I'm a fan of mesh systems.
