harrielv
Jan 11, 2013Follower
Deleting existing connection WN3000RP
I used my WN3000RP at home and I used a 16 digit WPA2 key to connect to my Fitzbox router. I am on holiday now and I want to use the extender. When I switch it on I see my definition I used at home ...
Advertman
Jan 12, 2013Aspirant
Well that's easy your factory setting reset failed you have to turn on the device and then hold the button for about 7 seconds then some leds will go off and the factory reset wil start.
Any way when you forgot a wpa2 you can also use the wps button 1 is the one under the on and off button.
Then select wps login on the device you want to login with.
The device will connect without using the wpa key.
