RSLady
Jan 10, 2019Aspirant
determine if certain ports are open
As I know enough about all of this to be dangerous, I need to determine if ports UDP 500, UDP 4500 and UDP123 are open. Can someone please give me step by step instructions on how to do this? It is a Netgears Genie WNR2000v3. Thanks! I am attempting to use a 4G Cellspot and since it is not setting up automatically, this is the first step to see why before calling my cell phone carrier.
Try https://portscanner.standingtech.com/
You set the IP address to the public IP address of your router.
- RSLadyAspirant
Thank you so much for the link. As it turns out, the cell spot that was sent to me is defective and a replacement is being sent. I will hold onto the information you provided just in case I have an issue other than an equipment failure.
