Justkillamojo
Apr 02, 2020Follower
device has no drivers installed
i have downloaded the support folders from netgear, all three versions in hopes that it will work. but when i go to search for drivers none of them work. i have restarted my computer and uninstalled ...
Apr 03, 2020Guru - Experienced User
what computer and operating system are you installing on?
How are you doing the install?
what error is it giving you?
start by uninstalling all the drivers/software for the A7000.
Make sure the wireless device is unplugged for setup.
Then install the drivers.
then reboot and plug in the wireless device
