Maril
May 28, 2020Aspirant
Device led is off
My device led light is off. Does anyone know how to fix it?
Maril
May 29, 2020Aspirant
Thanks for the reply. I reset the settings but cannot connect. The device led was on but no internet. Any idea why?
- plemansMay 29, 2020Guru - Experienced User
Maril wrote:
Thanks for the reply. I reset the settings but cannot connect. The device led was on but no internet. Any idea why?You factory reset the extender? Did you reinstall it? Did you do it using the wps method or using the installation wizard?
What router are you connecting to?
I'd recommend using the smart installation wizard.
- MarilMay 29, 2020AspirantI did the installation wizard. And factory reset. It used to work but the last week is not. Router Hub 3.0
