roverbill
Nov 29, 2019Follower
Device light not lit ex6110 ac1200 other 3 lights ok I have done a WPS reset but still the same
- Nov 29, 2019
The device light lights up when something is connected to it. Do you have a device connected to it?
You put the other lights are ok. What color are they?
https://www.netgear.com/support/product/EX6110
NetGFunkAc1200
Feb 27, 2024Aspirant
Not sure why this says problem solved but I'm having the exact same issue. My device light has always been on until today. I keep 3 devices connected to it; however, now my connections work for short periods of time. For streaming, every 10-20 minutes I drop service and have to recast. So, is the light going out a warning sign that the device likely needs to b stripped down or replaced?
- plemansFeb 28, 2024Guru - Experienced User
NetGFunkAc1200 I'd start your own thread versus jumping on someone elses thread.
