tdnishio
Apr 26, 2021Aspirant
Device: Red light stays on N300 EX2700 even if plugged in next room
Apr 28, 2021Guru - Experienced User
Which red light? It has several led's.
What router is the EX2700 connected to?
Did you set it up using wps or using the installation assistant?
tdnishio
May 04, 2021Aspirant
Red light stays on the Device.
Router is from my internet provider Consolidated Communications.
I believe it was installed using Netgear's installation protocol.
If you need more clarity than what I have provided, please let me know, what more specific you need.
- plemansMay 05, 2021Guru - Experienced User
tdnishio wrote:Red light stays on the Device. ----Which led? That's key.
Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it?
I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked.
If you need more clarity than what I have provided, please let me know, what more specific you need.----Yes I need more clarity. Actualy details helps. I'm not there to see whats going on or what you did so you need to be specific.
- tdnishioMay 05, 2021Aspirant
plemans wrote:
tdnishio wrote:Red light stays on the Device. ----Which led? That's key. Answer: The far top right LED, that is labelled Device.
Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it? Answer: ZYXEL Model# VMG4927-B50A
I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked. Answer: Netgear Installation Assistant
The "device" led is for devices connected to the extender. not the extenders connection to the router.
And the problem is that its a single light. so if more devices are connected, some could be fine but others have a poor connection.
You can log into the extender and check the connected devices list.
