tdnishio
Apr 26, 2021Aspirant
Device: Red light stays on N300 EX2700 even if plugged in next room
tdnishio
May 04, 2021Aspirant
Red light stays on the Device.
Router is from my internet provider Consolidated Communications.
I believe it was installed using Netgear's installation protocol.
If you need more clarity than what I have provided, please let me know, what more specific you need.
May 05, 2021Guru - Experienced User
tdnishio wrote:Red light stays on the Device. ----Which led? That's key.
Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it?
I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked.
If you need more clarity than what I have provided, please let me know, what more specific you need.----Yes I need more clarity. Actualy details helps. I'm not there to see whats going on or what you did so you need to be specific.
- tdnishioMay 05, 2021Aspirant
plemans wrote:
tdnishio wrote:Red light stays on the Device. ----Which led? That's key. Answer: The far top right LED, that is labelled Device.
Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it? Answer: ZYXEL Model# VMG4927-B50A
I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked. Answer: Netgear Installation Assistant
- plemansMay 05, 2021Guru - Experienced User
The "device" led is for devices connected to the extender. not the extenders connection to the router.
And the problem is that its a single light. so if more devices are connected, some could be fine but others have a poor connection.
You can log into the extender and check the connected devices list.
