Gmoney512
Dec 03, 2019Tutor
Devices not connecting to ax6000 extender
I have the ax8(ax6000) range extender.. the problem I'm having is once I get the device up and running..my devices will connect..then after a while the devices will not connect to it, even though the ...
Christian_R
Dec 09, 2019NETGEAR Employee Retired
Hi Gmoney512,
Welcome to the community! Would you mind telling me what firmware version the extender is on? Please ensure that your extender is on the latest firmware version. You may need to factory reset your extender and run through the setup assistant again.
https://kb.netgear.com/000061293/EAX80-Firmware-Version-1-0-0-36
Christian
Gmoney512
Dec 12, 2019Tutor
It's the latest..I figured it out..I had to lower the 5ghz bands to 2400mbps..now the extender stays connected...it would disconnect at the 4800mbps on the 5ghz bands
