witwitchery
Dec 16, 2020Tutor
Devices unable to connect to EX7700 extender networks.
Purchased the EX7700 extender in late March and it's worked great up until last week, when my mobile devices began to get booted off the 5G network with the 'incorrect password' error. It was only mo...
Dec 16, 2020Guru - Experienced User
What router are you connecting to?
What version of the firmware are you on?
Are you on version 1.0.0.210 of the firmware?
If so, downgrade to the 1.0.0.206 version, factory reset, and reinstall. After reinstall, disable auto-updates. I've seen a coupe posts where people are having issues on the latest firmware.
SoCaliFox
Feb 03, 2021Aspirant
I'm having issues after updating to this firmware upgrade as well. How do I downgrade?
- plemansFeb 03, 2021Guru - Experienced User
to downgrade, you simply go to the support site and download the firmware version you want.
then follow the manual firmware update process from the manual but use the firmware you downloaded.
- SoCaliFoxFeb 03, 2021AspirantThank you!
- witwitcheryFeb 28, 2021Tutor
Thanks plemans! I've been putting off the downgrade for... no good reason at all, but have finally made the switch. Hopefully this will do the trick, as working has become increasingly difficult on the 2.4gHz network as my work computer slows down even more due to age.
- DavidRCMar 01, 2021Apprentice
There is a new version of the firmware that does not seem to have the problems of the 0.210 firmware:
https://kb.netgear.com/000062873/EX7700-Firmware-Version-1-0-0-216
