Wipster
Feb 07, 2012Aspirant
DG834Gv3 - WG602v4 WDS WPA2
Hey all,
Yes this old chestnut but after lots of reading and conflicting (old) information I think just asking might be the best way.
I have seen reports of this combination of devices working with WPA2 and WDS in some comments however they do not mention the hardware version of the WG602 [1].
It seems that the latest firmware for the DG834Gv3 (4.1.40) allows for WPA2 to be used in WDS mode, and also the option is available in the WG602v4. However I have been unsuccessful in getting them to work together, they work fine without encryption so the settings are good.
Looking into the release notes for the WG602 series I see the latest firmware for the v3 model (1.2.5) state that WPA2 authentication has been fixed [2]. Will the v4 get the same treatment? Or can anyone confirm that the WG602v3 can be made to work with the above router?
[1] http://www.bencarpenter.co.uk/wireless-repeating-with-the-netgear-dg834gv3-and-wg602v3
[2] http://support.netgear.com/app/answers/detail/a_id/762/session/L2F2LzEvdGltZS8xMzI4NjYxNzM1L3NpZC9HMVFXNThRaw%3D%3D
- jmizoguchiVirtuosowithin WG602 each other may do WPA, WPA2 but DG will only be WEP or no security
- WipsterAspirantHi,
Thanks for your speedy reply, the comments in [1] give the impression that since 4.1.40 for the DG WPA2 was working, are they mistaken?
Also it seems that inter DG834Gv3 WDS using WPA2 is possible since firmware 4.1.40 [3]
[3] http://beusergroup.co.uk/technotes/index.php?title=Netgear_WDS - jmizoguchiVirtuosotry it and you will see it
