gcolace
Dec 11, 2012Aspirant
DGN2000 + WG602v4 problem
Hi all. I'm trying to realize an infrastructure with a DGN2000 modem - router and a WG602v4 in order to connect my TV to internet. The modem is connected to the ADSL and I'd like to use the WG602...
gcolace
Dec 13, 2012Aspirant
jmizoguchi wrote: you are expecting to et 192.x IP on wifi device right?
Yes you're right
if you setups static IP does pass any traffic?
No. If I set a static IP no traffic passes from WG to device.
How can I test the WG is OK.
I read something on the forum about to re-install firmware....
What do you think about this.
thanks in advance.
