sfarley
Nov 23, 2011Follower
DGN2000 LAN ports do not recognize AirPortExtreme
I have a DGN2000 which connects and broadcasts wirelessly. I have a new Apple AirPort Extreme Base Station, so I now want my DGN2000 to bridge to the AEBS so that I can use its wireless instead. Unfortunately, when I plug my ethernet cable from the DGN2000 LAN to my AEBS WAN, neither device recognizes that the cable is plugged in. Is my DGN2000 having ethernet problems?
- jmizoguchiVirtuosodo you have any other device you tested all the LAN ports of the DGN to see working fine first?
- levonkAspirantI am having a similar problem. The DGN2000 connects wirelessly to my laptop. The WAN port of the Airport Extreme is connected to the LAN of the DGN2000. The connection is constantly dropping. The amber light on the Airport flashes, then green light comes on, and it repeats. The interval between the light changes are 2-3 seconds. On the DGN, the port light is on (green) when the light on the Airport is green, and it is off when it is amber on the Airport. I checked the LAN ports with my computer and they all work fine. The are all green all the time, flashing when data is transmitted. The Airport is in bridge mode. I tried the DHCP and NAT but it gave an error: double NAT.
