iCaptainChaos
Jan 26, 2013Follower
DGN2000 Power problem
Hi
This doesn't happen all the time, but recently, when I press the "power" button at the back of my DGN2000 router, it starts to light up (power light) waits 3 seconds and then just powers off.
I have to press the rear power button 2 or 3 times to get it to "load".
Once it is powered up & connected, there is never an issue.
A friend said that it is likely to be the capacitor failing, and I might as well get a newer, better Netgear router.
Is he right and what should I go for? I need a huge range to connect top of house to bottom of house (3 storys). And speed too, if possible.
If I have to go for a new router, should I go for the expensive ones (£120 > £200) or will a £80 > £150) router be ok?
Thanks for any advice given.
Ian
Ian
1 Reply
- jmizoguchiVirtuosoDGN2000 is not access point
Belongs to root of http://forum1.netgear.com/forumdisplay.php?f=33
Repost and do not click any other model categories :)
