RobTripp
Jan 15, 2013Initiate
Dgn2200 v3 use as repeater
Hi, I'm trying to set up the Netgear N300 DGN2200 v3 as a wireless signal amplifier between my British Telecom Home Hub 2 and some rooms in the house where the signal is weak. Any ideas? What settings should I use on the Netgear equipment? The BT Home Hub has a 'Wireless Association' button. Thanks.
1 Reply
- jmizoguchiVirtuosohttp://vpncasestudy.com/download/WDS/WDS_Concept.pdf
you will be limited to WEP/54Mbps or no security
