glnta
Feb 19, 2012Novice
DGN3500 + DG834GT Access Point
Hi All. DGN3500, Firmware 1.1.00.33 DG834GT, Firmware 1.03.87 I am using the DG834GT with a patch cable to the DGN3500 as an access point. I have configured both routers to the same SSID, Ch...
glnta
Feb 19, 2012Novice
jmizoguchi wrote: use different SSID , different channel
you are working with two different wireless , one only supports 54Mbps and one is put to 300Mbps
I did initially set up two SSIDs, PBS & PBS2, but found that it was hit and miss for some reason whether I could connect to one of them or not. And I also wanted to keep uniformaty with just one network.
Could I not just put the DG834GT on a different channel ?? saying this I dont think this would make any difference.
Was thinking of purchasing the new WNDR4500 and couple that with my DGN3500 and put the DG834GT where it belongs ...... in the bin !!
I would have to setup two different SSIDs then because support is 900 (as if !!) & 300 mbps respectively.
