glnta
Feb 19, 2012Novice
DGN3500 + DG834GT Access Point
Hi All. DGN3500, Firmware 1.1.00.33 DG834GT, Firmware 1.03.87 I am using the DG834GT with a patch cable to the DGN3500 as an access point. I have configured both routers to the same SSID, Ch...
jmizoguchi
Feb 19, 2012Virtuoso
matching the unit is better when you are doing SAME SSID
if you are not planning to roam throughout the location use different SSID and let each wifi device to use specific SSID.
