glnta
Feb 19, 2012Novice
DGN3500 + DG834GT Access Point
Hi All. DGN3500, Firmware 1.1.00.33 DG834GT, Firmware 1.03.87 I am using the DG834GT with a patch cable to the DGN3500 as an access point. I have configured both routers to the same SSID, Ch...
jmizoguchi
Feb 23, 2012Virtuoso
Just because it work on dlink does means should work on others
Chipset in both side can cause the issues. You find issues like this all the time in the thread
