glnta
Feb 19, 2012Novice
DGN3500 + DG834GT Access Point
Hi All. DGN3500, Firmware 1.1.00.33 DG834GT, Firmware 1.03.87 I am using the DG834GT with a patch cable to the DGN3500 as an access point. I have configured both routers to the same SSID, Ch...
glnta
Feb 23, 2012Novice
I will totally remove the DGN3500 later and put in its place the DG834GT on its own, turn on DHCP and see if I can connect to it via WIFI with the centrino ultimate N6300, if I can then there is obviously no compatiability issue. If there is I will throw the 834 in the bin !!
