rollerrrr
May 21, 2020Follower
DHCP Issue
My network setup includes a C7000 Modem Router and an EX8000 WiFi Extender. I found that devices that connect to the WiFi extender may be given the same IP address sometimes. My current solution for ...
gibs66
Oct 18, 2020Initiate
I have exactly the same problem with an EX7300 running the latest firmware. I found that shortening the DHCP lease time helped some devices. There is definitely a problem with the DHCP snooping/intercept/reply on the EX7300. My laptops work fine now, my iphones are stubborn and I finally gave up and assigned IP addresses.
- Wolf_666Jan 20, 2021Luminary
Same issues with Extender 6420 and Router RAX200 (DHCP Server).
The extender is connected to an unmanaged HP Switch, using fast lane capability (5GHz ONLY). 2.4 radio is disabled.
