Soleous00075
Jan 13, 2022Initiate
DHCP issue
Hello Guys, I was just wanting confirmation if the EAX20 and the EX3110 do not have dhcp servers. I am trying to connect the EX3110 to the EAX20 which it does but it cannot get an ipaddress. it work...
- Jan 13, 2022
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Jan 13, 2022Guru - Experienced User
Thank you.
nielsvds
Jan 16, 2022Luminary
DHCP or dynamically get an IP address is activated by default see page https://www.downloads.netgear.com/files/GDC/EAX20/EAX20_UM_EN.pdf (page 37 - 38 of the manual)
Also for EX3110 : https://www.downloads.netgear.com/files/GDC/EX3110/EX3110_UM_EN.pdf (page 25 of the manual)
- Margaret76Jan 17, 2022Aspirant
thanks, i was looking for this solution. cheers
- Soleous00075Jan 20, 2022Initiate
thank you nielsvds , but this was not what I was looking for. Though I appreciate your time.
- nielsvdsJan 22, 2022Luminary
Auto assigning IP addresses from a pool of IP address is called DHCP service. What is your definition of a DHCP service? By default DHCP is activated like I already said before.This is what is written for yor EX3110
The extender comes set up to use a dynamic IP address, which is the correct setting for most home networks. So it already received an IP address of the DHCP service that is running on your router. Also this is written for EAX20 : The extender comes set up to use a dynamic IP address, which is the correct setting for most home networks. But you are right there isn't a DHCP server option where you can change i DHCP IP range, it is only a client. I was a bit too quick to answer.
