Tymok
May 14, 2021Aspirant
DHCP pass through issue ex7500
Hi, I’ve got a ex7500 extender Everything works fine and after a couple of days devices connect to my ex7500 but don’t get dhcp address . I see them connected but with no ip. Everything returns to ...
Tymok
May 15, 2021Aspirant
Ex fw 1.0.0.72
Orbi fw 2.6.2.104
ex7500 manualy Connected directly to the orbi router (lan 10.0.0.1) (wan 192.168.1.134)
Providers modem in router mode - Upc compal (192.168.0.1) 400/40 mbps
orbi satellite 1st floor, orbi router 2 floor, ex7500 3 floor.
Daisy chain is disabled.
satalite and ex have a good link to the router.
the ceiling between the orbi and its satalite is concrete. The ex doesn't connect the satalite, it connects directly to the router.
same happens when the orbi satalite is switched off.
The ex works for a couple of days and devices stop getting dhcp.
when I take them downstairs they connect to the orbi and work fine.
after restarting the ex, devices start to work normally
May 17, 2021Guru - Experienced User
Tymok wrote:Ex fw 1.0.0.72
Orbi fw 2.6.2.104
---Issues with double nat? cascading routers isn't a ideal plan.
https://kb.netgear.com/30186/What-is-Double-NAT
---Does it work with daisy chain enabled? If the cement wall is between router and the satellite, it means the cement is also between the EX and the router. Cement is one of the best blockers of wifi.
The ex works for a couple of days and devices stop getting dhcp.when I take them downstairs they connect to the orbi and work fine.---so, If the cement floor/wall isn't between them, there isn't any issues? Seems to indicate a poor signal with the cement in between and eventually dropping signal.
