HuubIT
Dec 15, 2021Aspirant
DHCP problems Nighthawk R7000 and Mesh extender X6 EX7700
Hi, I recently purchased the Nighthawk X6 EX7700 as a range extender for my Nighthawk R7700 router. EX7700 Firmware Version 1.0.0.222 R7000 Firmware Version 1.0.11.128 Configurate using t...
Dec 15, 2021Guru - Experienced User
What modem/gateway is the R7000 connected to?
with the R7000 having a 10.*.*.* subnet, it makes me think you're running a gateway with its own router functionality.
does your gateway have the R7000 setup in its DMZ? Or the R7000 in access point mode?
HuubIT
plemans wrote:What modem/gateway is the R7000 connected to?
I'm living in the Netherlands, so KPN Box 12 is the modem
- plemansDec 15, 2021Guru - Experienced User
- HuubITDec 15, 2021Aspirant
plemans wrote:does your gateway have the R7000 setup in its DMZ? Or the R7000 in access point mode?
It's just wired on one of the 4 ethernet ports on the back of the modem, so I assume access point mode, out of the box install no DMZ configurated.
Assuming is a poor choice.
If both are in router mode, you're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NATIt doesn't always cause an issue but it can.
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
