Karaptian
Nov 18, 2024Aspirant
Disable 2.4 Ghz network
I have a Nighthawk MR60 system. I would like to disable the 2.4 Ghz network. I followed the following steps, but was unable to locate where I can disable the 2.4 GHz network. Log in to the r...
Nov 19, 2024Guru - Experienced User
I know you can separate them out but I don't think you can entirely disable it.
Why are you trying to do this?
