alaland2's avatar
alaland2
Follower
Jul 19, 2011
Disable Windows Logon
I hate that I have to logon to Windows and want to get rid of it. When I went to Control Panel, Users, Change logon, it told me Netware was controlling client services and I had to change/disable that. Unfortunately, I can't figure out how to do that! I've read until I'm cross-eyed but haven't found a thing about it anywhere on Netgear site or here, so I figure it must be incredibly simple! HELP PLEASE!
:confused:
Thanks!
1 Reply
  • XP_FixLogon.exe - Fix Windows® XP Logon/Restore Welcome Screen
© Doug Knox - 03/25/2002
    Usage: Download XP_FixLogon.ZIP and save this file to your hard drive. Navigate to where you saved it and double click the file. Extract XP_FixLogon.exe from the zip file and double click it.* The program will tell you if repairs are needed or not.
    This utility checks for the correct GINA value in the Registry and will allow you to restore it, if its incorrect.
    http://www.dougknox.com/xp/utils/XP_FixLogon.zip
