BKSinAZ
Jul 14, 2013Aspirant
DM111psp and Airport extreme problems..
Need Help- After breaking my Actiontec dsl modem, as of 07/13/2013 I have a new DSL modem DM111psp. When the ethernet cable is connected directly to my computer, I have internet. When I bridge the ...
BKSinAZ
jmizoguchi wrote: Usually PPPoA can not be authenticated at router so prior to changing the DSL unit other one was modem/gateway. Authentication was done at DSL unit
With DM111p unit plug computer directly and setup authentication first and check Internet if that works AE should be plugin to dm111p with Ethernet option to get private IP from the dm111p
I am kind of a amature when it comes to computers and trying to follow you...
When I first setup the DM111psp, it was connected directly to my computer and internet worked.
I then plugged the DM111psp into the AE. After a few minutes of adjusting password setting in AE, the light went from amber to green. (green is good :) ) Inside the menu settings of the AE, where the option to set AE to Ethernet is, the AE auto populated the modem's ip address. I am at work now, so not at that computer, but I seem to recall the ip addy being 192.168.0.1 AE has been set to Ethernet.
