BKSinAZ
Jul 14, 2013Aspirant
DM111psp and Airport extreme problems..
Need Help- After breaking my Actiontec dsl modem, as of 07/13/2013 I have a new DSL modem DM111psp. When the ethernet cable is connected directly to my computer, I have internet. When I bridge the ...
jmizoguchi
Jul 17, 2013Virtuoso
With DM111p unit plug computer directly and setup authentication first and check Internet if that works AE should be plugin to dm111p with Ethernet option to get private IP from the dm111p
Read again
You use PPPoA authentication on DM11P
Not sure why you are changing to the setting to bridge on AE. You should seutp on DHCP for internet port
