clarman68
May 14, 2020Follower
Do I need an extender; if so, how can I be sure my current Negear N300 is working?
I just bought and have installed an AC1600 WiFi Cable Modem Router, Model C6250. All seems to be working fine except a previously installed older Range Extender: N300 Model EX2700. Do I need it?; i...
May 14, 2020Guru - Experienced User
you can factory reset it and reinstall it.
But if you have adequate coverage, you might not even need it.
