Kiwi58's avatar
Kiwi58
Guide
May 01, 2024
Do you have to purchase support past 90 days to get access to firmware updates?
Hello,
I have a ex3700 range extender. It seems to work well. I am well past the 90 days of complimentary support. I don’t seem to have a way to update the firmware. I have read that Netgear won’t allow the extender to update the firmware unless you buy the support. Is that true?
  • FURRYe38's avatar
    No.
    If you have the Extender connected and in operation, and if there is an available FW update from here:
    https://www.netgear.com/support/
    You can log into the extenders web page and manaully update the extender using a PC and web browser.
  • plemans's avatar
    what actual firmware version are you on?
    Is there a reason you think you need a firmware update? Most update only fix security issues that most users will never see.
    Not sure if you're running into a performance issue or what you want it to fix
