Daddysmell
Jun 10, 2018Guide
Does extender with other party router
Is the extender able to work with linksys routers?
- Jun 18, 2018
Hi Daddysmell,
You can check the stability of your Internet connection by bypassing the router and connection your computer straight to your ISP's modem and see if the issue occurs. If it does, we recommend contacting your ISP.
Dexter
Community Team
DexterJB
Jun 11, 2018NETGEAR Moderator
Hi Daddysmell,
Welcome to the community!
Yes, most, if not all NETGEAR extenders work with other home routers that use the same wireless standard.
Dexter
Community Team
Daddysmell
Jun 12, 2018Guide
I have a r7000 router, Do you think I need to upgrade if , 1) my PS4 is saying no connection 2) everyone in the family is asking what happen to the internet or 3) should I upgrade my internet speed.
- DexterJBJun 14, 2018NETGEAR Moderator
Hi Daddysmell,
1. Please make sure that the PS4 is connected to the network either via WiFi or Ethernet.
2. If you are experiencing frequent disconnects, please make sure that the connection from your ISP's modem is stable.
3. That stability/reliability of your Internet connection may not be related to your subscription speed.
Dexter
Community Team
- DexterJBJun 17, 2018NETGEAR Moderator
Hi Daddysmell,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- DaddysmellJun 17, 2018Guide
Still having the problem.
I thing I need to upgrand my router. I have several wifi device plus I just add 4 more that run off of Hotspot or I have to us my phone as one.
