Daddysmell's avatar
Jun 10, 2018
Does extender with other party router
Is the extender able to work with linksys routers?
  • DexterJB's avatar
    DexterJB
    Jun 18, 2018
    Hi Daddysmell,
    You can check the stability of your Internet connection by bypassing the router and connection your computer straight to your ISP's modem and see if the issue occurs. If it does, we recommend contacting your ISP.
    Dexter
    Community Team
