WillG1
Aug 31, 2021Follower
Does the EX3700 work with T Mobile Internet Gateway?
Hello, I've been struggling with trying to connect my EX3700 range extender to T Mobile's 5G Internet Gateway. I had no problems connecting to Fios a few years ago. Just recently moved, and switc...
Aug 31, 2021Guru - Experienced User
The tmobile gateways are pretty new and not many are using them.
Even tmobile isn't saying a whole lot on their forums on what works with their gateways.
Wi-Fi extenders for the T-Mobile gateway | T-Mobile Community
theoretically, most devices should work but in reality, it doesn't always work. Some routers have potential for mesh/nodes built in and that can cause issues.
Have you tried going into the gateway and setting up the extender with a static ip address?
Or checking if the router has any features like verizon uses (self organizing network or 'son")
