ARPcPro
Jan 05, 2020Aspirant
Does WPN802 supports client mode?
I would like to connect a device with only a wired connection to my wireless network. Can I use the Rangemax Wireless Access Point WPN802 to do that?
Christian_R
Jan 10, 2020NETGEAR Employee Retired
ARPcPro - You should have no issues using the WPN802. If you run into any, you may always contact our Support Team using the link below.
https://www.netgear.com/support/default.aspx
Christian
