LewJFab
Nov 10, 2024Tutor
Does X4 AC2200 & X6 AC2200 work with BE6500?
I have an AC1900 R7000 router on the ground floor of my house. I have an X6 AC2200 extender on the second floor. I have an X4 AC2200 extender in the basement. This has worked well for a couple...
LewJFab
Nov 18, 2024Tutor
Thank you for your time and answer. Your comments had me reconsider and I installed a complete new Orbi mesh system. I went with the RBK753P as a compromise of getting a complete system, upgrading my system functionality, and price.
Nov 18, 2024Guru - Experienced User
good luck with them!
What system did you go with?
- LewJFabNov 18, 2024Tutor
Your comments had me reconsider and I installed a complete new Orbi mesh system. I went with the Orbi AX4200 (RBK753P) as a compromise of getting a complete system, upgrading my system functionality, and price. Got it for $470. Installed it Friday. Easy install. Been working great since...my Spectrum speed is 600mps. I really wanted to go all the way to the Orbi wifi-7 system, but couldn't justify the $1000K for my needs.
- plemansNov 19, 2024Guru - Experienced User
for the speeds you're paying for, that system is perfect. It'll handle a ton of connections and do great.
Good choice
