spikerz
Sep 04, 2013Aspirant
doesn't connect. Help me please.
Hi to all,
My network config is: Netgear DG834G v3 with ip 192.168.0.1 configured in WDS mode Bridging point to point wireless with my access point netgear WG602 v4. I use the channell 13 and a wep key 128 bit.
I've bought WN1000RP to extend my wireless range.
i've tried all the possible ways to connect the WN1000RP to my network but doesn't work. I've tried with genie automatic and manual configuration but it doesn't work.
The ip of my router is 192.168.0.1 access point 192.168.0.227 and the other pc connected to my network have ip 192.168.0.2 192.168.0.3 192.168.0.4 192.168.0.5 and so on.
I've tried to change channel with 11 and in this way the WN1000RP with genie mode can see my wireless network then i set my wep key but it says doesn't connect.
I've tried also to change the ip of the WN1000RP in 192.168.0.250 but it doesn't work.
How can i solve this problem ?!?
Thanks a lot.
Thanks a lot.
1 Reply
- jmizoguchiVirtuosoDG834xx is not WR1000RP. It is Super-G wireless router
Belongs to
http://forum1.netgear.com/forumdisplay.php?f=34
Repost
