Pattrick
Jun 06, 2012Novice
Drop / Unstable
Hi guys,
I recently got a Netgear Wi-Fi booster.
Using a wireless card I managed to get access to the NetGear and configured it to receive wirelesscon1 from the wireless router I got down the first floor.
The signal was boosted and worked perfectly. But the moment my friends wanted to connect to the NetGear it dropped all connections. Right now I use only one connection, my main PC. But I got serious lag issues, and I need to restart the router every day, for it drops the signal.
Question 1: What can I do?
The other problem is, since I set wirelesscon1 to the Netgear, I can't access the Netgear no more! When I write the IP, it takes me directly to the Router!
Question 2: How do I access my Netgear again? (we got two routers, I want to set the Netgear to get wirelesscon2 but I can't get inside it)
Thanks.
Thanks.
- jmizoguchiVirtuosologin the router with ETHERNET CABLE
also you posted wrong place for router
belong under here
http://forum1.netgear.com/forumdisplay.php?f=31 - PattrickNoviceFirst time I logged in the Netgear I didn't use Ethernet Cable. If I'm trying now, I can only reach the main router.
This is confusing.
I will take the netgear down, will connect it to the router via Ethernet Cable and pull it as close as I can to the first floor.
