rozel
May 26, 2014Aspirant
Dual Band Routers - Are They An Improvement?
Hi all I have been successfully using a WN2000RPT Wireless Extender for a few years now, extending the wireless range in my property to a remote bedroom. However the downside is that when it comes...
jmizoguchi
May 26, 2014Virtuoso
Then how to set it up to gain more bandwidth compared with existing WN2000RPT.
WN2000RPT is 300Mbps for LAN transfer so if you need more that that you will need 802.11ac router and extender ex6200 to get the fastest LAN speed you can achieve.
This will be only good if you are need LAN to LAN transfer streaming, file transfer otherwise unless you have super fast internet broadband speed I don't see the changes will makes any better
My Broadband speed averages around 78Mbps down and around 19Mbps up.
existing setup should do just fine ..
