rozel
May 26, 2014Aspirant
Dual Band Routers - Are They An Improvement?
Hi all I have been successfully using a WN2000RPT Wireless Extender for a few years now, extending the wireless range in my property to a remote bedroom. However the downside is that when it comes...
jmizoguchi
May 26, 2014Virtuoso
You can only use single band with wifi device
Makes no difference other than you get to choose which band
Off course with 802.11ac uou have to use 5Ghz but still looses performance plus less than 100Mbps Internet current or new extender makes no difference
If Yiu want better perfomavr use power line to run cat5e/6 cable
