rozel
May 26, 2014Aspirant
Dual Band Routers - Are They An Improvement?
Hi all I have been successfully using a WN2000RPT Wireless Extender for a few years now, extending the wireless range in my property to a remote bedroom. However the downside is that when it comes...
rozel
May 27, 2014Aspirant
My sincere apologies for the confusion, caused as you say by an incorrect Subject Title. I have corrected this.
So can I again ask how these Dual-Band Extenders work. For example: if I connect the router to the extender using the 5ghz band and then either connect the device (a PS3) via ethernet to the extender or via wifi using the 2.4ghz band will either of these methods be better than what I get at the moment with my single band Extender? If so which method of connection would better?
