gnun
Dec 23, 2024Aspirant
EAX-15 Extend Enet connection
Can I plug my #EAX-15 extender directly into an ethernet connection to my router and extend the network without a wifi connection to my router? When I purchased the unit I was told this would work b...
Dec 23, 2024Guru - Experienced User
You can but when you go through setup on it, it needs to be switched to access point mode. Thats the mode for hardwired to the router.
gnun
Jan 26, 2025Aspirant
Thanks, but I can't find the "access point" setting when I configure the extender. I've reset to factory default and configured with Nighthawk and with the browser connection. The only option I have is to configure the 2G and 5G wireless connections?
- plemansJan 27, 2025Guru - Experienced User
here's the guide
https://kb.netgear.com/000060286/How-do-I-install-my-NETGEAR-WiFi-range-extender-as-an-access-point
and here's a video guide someone made for the EAX80 that should be the same. I have the EAX80 and EAX17 it it was the exact same.
https://www.youtube.com/watch?v=ucnu1Wrsr_Q
