BioBill13
Jul 30, 2025Follower
EAX11 Placement
My WiFi Extender is in a separate room about 50 feet from my WiFi Router. The signal is 4 bars. My car which requires a WiFi connection is parked outdoors another 50 feet from a brick wall. The ex...
Jul 30, 2025Guru - Experienced User
Would need to try a outdoor designed Extender and see. the Brick wall maybe problematic as this material will inhibit good signal travel.
WAX###Y series APs would be something to review as they are rated for outdoors use.
Might consider a power line adapter from the main building out to the car area if power is on same circuit and place a actual AP in this location.
Could run just CAT6A STP Lan cable there as well and install an AP.
