Larrsz
Apr 09, 2023Guide
EAX12 doesn't see and won't connect to my 5ghz network
I have AT&T Fiber with a BGW320-500 router/gateway. It broadcasts one SSID for both networks allowing for the best connection for each specific device. I have a couple of dead (or very poor) wifi spo...
Apr 09, 2023Guru - Experienced User
What firmware is on the EAX?
Are you using any special characters in the ssid/password?
- LarrszApr 10, 2023Guide
Firmware is 1.0.3.34
The SSID and password both use _ in them. I also have a couple of neighbors using the same AT&T device, with different SSIDs of course, and they also only show under the 2.4Ghz network as well. Nothing from them shows in the 5Ghz table either.
- plemansApr 10, 2023Guru - Experienced User
Have you tried setting it up using the wps method?
try that and then log into the EAX's status page and get a screensnip.
I'll do that today. I also did verify that my phone can connect with a strong signal via 5Ghz to the router from the same point where the extender is.
