lumpy123
Feb 14, 2021Aspirant
EAX15 - AX1800 WiFi Mesh Extender problems
Hello I moved home about 2 months ago and brought my home router which was a Nighthawk C7000 with me as it worked pretty well on Comcast service In my new home i again used comcast with the s...
lumpy123
Apr 21, 2021Aspirant
Hi There
I would recmommend starting a new thread with these questions.
I eventually gave up on the device and bought the Xfinity xPods as it had a few other problems.
The more threads for this unit the more it may make the manufacturer to fix its problems or make things clearer in their documentation/.litreture
Cheers
BamaGuy
lumpy123 Ironically, I bought these because the xFi Pods were not optimal for me! They aren't WiFi 6, whereas the Gateway itself is...go figure. I hope they work better for you.
lumpy123 wrote:Hi There
Cheers
Thanks, I will start a new thread,
- lumpy123Apr 22, 2021Aspirant
Different strokes for different folks!
I got the xPods mainly becuase however the xFi controls work, they dont work with this router.
xFI could not identify units connected to the extender as connected to the network, so accordingly I could not set limits on time or parental controls on devices connected.
I found this out when I found my little one awake at 1am playing games online.
Also, I found the extender undependable from time to time and it seemed to cuase issues on the network.
I think it was something to do with how it handled IPV6 and / or DNS lookups
I found a thread online mentioning issues and that a reboot fixes it which is unworkable as a fix.
In the end I got fed up trying to trouble shoot when it happened which was mostly during bad times when the kids were homeschool;ing and my wife on a call.
In the end I just binned the router and went for the xpods, knowing comcasrt would have tested them together.
They seem towbe working ok.
Given they all have the same SSID, no meshing is really required
All the best
