Youen
Nov 27, 2022Aspirant
EAX15 and portal connection problem
Hello, I just bought a EAX15 to extend my wifi, but I can't access internet through it. Already tried the troubleshooting guide. My wifi needs to be logged in via a browser portal, I'm pretty sure the...
- Nov 27, 2022
Sorry, don't speak french (?) so the screen snip doesn't tell me much.
What router are you connecting it to?
And what ISP access is this?
Did you try setting it up using the installation assistant?
LIke I said, this extender doesn't support wisp mode which if you're trying to connect to a router that requires login access, it won't work. Wisp mode is what you need for that.
