gjhamilton1
Jan 25, 2021Follower
EAX15 Extender Set Up/Connect to Laptop
HELP! My husband thinks he knows what he is doing with what should be an easy set up on an Extender. How do I connect to it on my laptop? I should be able to see it as an option when choosing Wi-Fi...
Jan 25, 2021Guru - Experienced User
He's actually right (sorry!).
the EAX15 is a mesh extender. So if it was setup using wps or even the standard setup, it functions as a mesh. Meaning it uses the exact same ssid as the primary router and lets your devices roam between it and the router as needed.
