Giuliano351's avatar
Giuliano351
EAX15 Extender
Hello to everybody.  Recently I change my provider to SKY and I reconfigured my NETGEAR EAX 15 extender. .When I try to connect to # mywifiext for checking connections and settings I receive this mes...
  • Giuliano351's avatar
    Giuliano351
    Mar 10, 2024
    THANK YOU VERY MUCH INDEED !!!!!!   Clicking the link you give me I found the trick to solve my problem.  IT WORKS and I am very happy.   All is solved : thanks you again.
