Giuliano351
Mar 08, 2024Aspirant
EAX15 Extender
Hello to everybody. Recently I change my provider to SKY and I reconfigured my NETGEAR EAX 15 extender. .When I try to connect to # mywifiext for checking connections and settings I receive this mes...
- Mar 10, 2024
THANK YOU VERY MUCH INDEED !!!!!! Clicking the link you give me I found the trick to solve my problem. IT WORKS and I am very happy. All is solved : thanks you again.
Mar 09, 2024Guru - Experienced User
there's usually a "proceed anyway" option on these because its a browser issue.
If you google how to get around it, there's a ton of ways. here's one for example
Giuliano351
Mar 10, 2024Aspirant
