daves12555
Apr 27, 2026Tutor
EAX15 ...I have all green lights and then sometimes they go to red on the Client Link LED
I use a RAX41v2 with the extenders....So I have some cameras and TVs on the Extenders and one is set to Mesh and one set as extender.... They Both do it at times and go from Green to Red and I hav...
Apr 27, 2026Guru - Experienced User
daves12555 wrote:it will go to Red for Clients and stay that way a while and then go back to green
Per the manual, that means one of the client devices has a poor connection (obviously a temporary situation, since it goes back green).
In the case of the mesh (using the same SSID as the main network), this might be a client that normally connects to the router, but which decided to switch to the mesh extender - and then decided to switch back.
But assuming that the extender-mode EAX15 has a different SSID than your main network, it would have to be a client that is configured to connect to that EAX15.
