tesseract_
Feb 20, 2024Tutor
EAX15 in AP mode, WPA2+WPA3 security
I have an EAX15 that I was previously using as a mesh extender. It was able to extend my wifi network that was running WPA2+WPA3 security. I now have hardwired Ethernet available so I reconfigured th...
Feb 21, 2024Guru - Experienced User
I wasn't aware the AP mode removed that option.
What firmware are you on?
I don't have that extender to test with but I know my EAX80 had mixed mode in AP mode because I used it
tesseract_
Feb 21, 2024Tutor
I am on firmware V1.0.3.36. (The latest, as far as I can tell?)
- plemansFeb 21, 2024Guru - Experienced User
Looks like you're on the latest.
Got a screensnip of it showing the wpa2 or wpa3 only?
- tesseract_Feb 21, 2024Tutor
Sure, here's what I'm seeing.
- plemansFeb 22, 2024Guru - Experienced User
does the 2.4ghz have that option?
What happens if you enable smart connect? Does it give you the option then?
