internot
Jun 06, 2020Aspirant
EAX20 (AX1800 extender) will not connect via wifi or ethernet
EAX20 extender worked as intended for three days or so. When it worked as extender my laptop showed four available networks 2 2.4ghz and 2 5ghz. (as an aside, All had the same name. None had "_ext...
internot
Jun 08, 2020Aspirant
Thanks I will will try to revert to old FW.
Anonymous
Jun 08, 2020Could you post your results with the previous firmware?
The only reason I'm holding onto the new 1.0.3.80 firmware is due to smart connect.
